colossus3874
I just had to get a replacement Supreme and am having some issues. The old one I rooted with motochpper and then installed CWM recovery easily. The replacement didn't root with Moto and had to go a separate route and now CWM won't install either. I'm stumped. I type the commands correctly, recovery.img is where it should be and drivers are installed. Yet, when I type the command in ADB it says recovery.img can't be found. Any help??"
