141421356237
Hello guys,
I have a problem for a while now. My phone stopped working. Let me just tell you where it all started.
Okay so more than a year ago I purchased a My|Phone UNO Android phone and it is a version 5.1, right. It is running smoothly, it just have a storage shortage problem, which prevents me from updating it everytime there are updates available.
I believe the current version of it was March or February patch (Last time i checked it was 6.1.0 or 6.0.1), and I cannot update it to May patch. Because whenever I am updating it, it will have that android-guy-red-triangle-!-no-command logo, then it boots normally. But, from there it started many problems, one of which is whenever I finish charging the phone, there would be a problem connecting to the WiFi. So when I tried to connect to the Wifi and/or turn it on/off the phone will reboot and would get stuck to a bootloop (loading screen). I bypassed that bootloop a few times by taking the battery out and turning it on again. Then after charging it will start the process all over again. But after a few days it just stopped working.
It's been two weeks now since I last used my phone. And now there are no loading screen when I turn it on, it's showing the logo of My|Phone.
I tried the "Recovery Mode" via holding the power button and volume up key, but I am getting a "No Command" I also tried holding the vol up key for 10 seconds and tapping the power button but it is just not working for me.
