Help Recovery mode
I am trying to remove an update I have put to my phone. I am getting into the recovery mode and trying to go thru options there. I am able to navigate using Volume buttons but selecting an option with Menu button (no other buttons do anything) not triggering anything: I simply shows small Android image. Any idea?
Thanks
Thanks
Are you hitting the "Home" button at the bottom and not the on/off button? I made that mistake coming from the captivate as that was the way it worked on that phone. On the GS2 you need to use the home button to select in recovery.
