Help Recovery mode?
Is there ANY way to manually enter recovery on this tablet without having to boot it up first? I'm permanently stuck on a boot screen! Maybe a button combo from power off? Is there a flash tool I can use, or maybe force into recovery through ADB somehow?
Thanks,
Spec
I'm sorry, this is not a function we offer. If you are stuck on a boot screen, the two things to try are:
1. Reboot
2. Reset button on the back of the Meep
Try each method several times in a row. If you still cannot boot, then it is considered a hardware issue and your local Oregon Scientific call center would need to be the ones to assist.
