Root recovery not working
i cant get the recovery img to work on my behold 2... its rooted and has the BH_MAN 1.6 stock with touchwiz, i went into recovery mode and it didnt work. any help?
If you was using any Custom Rom's Before had the Updated tot eh Stock... It's not Going to work at all...
I have said this many of time my recovery only work on my Custom Rom's R9 & Warhead's & Future Releases..
If you are wanting to use the Stock 1.6, you will need to download the Recovery I have Posted in the Forums.. These Recovery's Posted will work with all, but lose feature's that was added into the recovery..
how do you get into recovery ?
Turn off phone and then press volume down, send key (green) and end key (red) all together until you see the recovery message. Dont press the menu button as it will wipe data. Use the send key to select things.
Sent from my Behold II using Tapatalk
