UPEngineer
Hello all,
I have a weird problem and I can't seem to figure it out. I have searched high and low and can't find an answer or even anyone that has this problem.
I was running a custom 2.2 rom with clockwork recovery installed via Rom Manager.
Anyways, I started having a few problems so I was going to take it to stock and redo everything.
I have the stock 2.1 sbf file and I put it back to my phone using RSD lite.
It installed fine except it changed my PRL number to some weird higher number and now I can't get my phone to activate because it has the roaming triangle and is roaming on US Cellular.
I reinstalled my custom rom and used rom manager to restore the image I had saved before I recovered and all is well except I cannot activate my phone because I can't see a verizon network.
I even went into the programming menu and replaced the SID, MDN and MIN with all the settings in my Droid X but no dice.
Any suggestions or tell me what i did wrong?
I have found a way to write a new PRL but I can't get the HW virtual port app to work. So basically I am stuck.
Thanks.
Thanks.
