Help Red charging light....
Hey,
Have you enabled it in the settings?
Settings > Display > LED indicator > check the top box ( charging )
Hope that helps ;)
does not show when the screen is on either.. only lights up when screen times out.
The only time I have ever noticed the "charging" LED is when the screen is timed out. If you look at the screenshot attached, that is the only time when it is supposed to display.
It is red when charging, but turns to green when it reaches 100% or there abouts... never watched to see just when it flips over to green.
Hey,
Hope that helps ;)
Yes, this is checked. It used to come on when I plugged it in to charge but for some reason does not anymore. The green light comes on when charged though.
