johnlgalt
Antidisestablishmentarian
Updated: 23 Sep 2011
The same tried and tested and true redraw fix works on our phones as well. Kudos to Tehsusenoh for testing this.
Prerequisites:
You must be rooted
Apply Redraw fix
Android Terminal Procedure:
ADB Procedure:
Enjoy the new redraw speeds.
Remove redraw fix:
Prerequisites:
You must have used the above procedure in order for this remove procedure to work
ADB Procedure:
NOTE: Some people will tell you that this is not a true fix, and it can have a deleterious or detrimental effect on your phone. YMMV. As always,
I am not responsible to what you do to your phone. This guide is provide as is, without any implicit nor any implied warranties or guarantees.
- Added method to reverse the changes, plus change reversal procedure (credit to Lars for the idea in this http://androidforums.com/bionic-all-things-root/416537-redraw-fix-bionic.html#post3230897 post
Prerequisites:
You must be rooted
Apply Redraw fix
- Open terminal
- type the following commands
Code:su cp /data/local.prop /data/local.prop.bak echo "ro.HOME_APP_ADJ=1" >> /data/local.prop exit
- reboot
ADB Procedure:
- Connect your device to your USB cable, make sure that Charge only mode is set for USB Connection:
Notifications --> USB Notification --> Select Charge only
- From a command prompt on your computer go to the {path}/Android/android-sdk/platform-tools/ folder, where {path} is the location of the Android SDK - it may be Program Files / Program Files (x86) is you downloaded the installer, or it may just be C: / D: / etc if you downloaded the .ZIP only
- Run
Code:adb shell su cp /data/local.prop /data/local.prop.bak echo "ro.HOME_APP_ADJ=1" >> /data/local.prop reboot
Remove redraw fix:
Prerequisites:
- Open terminal
Code:su cp /data/local.prop.bak /data/local.prop exit
- reboot
ADB Procedure:
- Run
Code:adb shell su cp /data/local.prop.bak /data/local.prop reboot
