I have been in the computer industry for a lot of years and have worked on a lot of machines. The Bionic is simply impressive. It is astonishing what can be done with it and how it brings some real new creativity into use.
<rant>
$600 for a computer ... where's the Reference Manual? The Bionic User Guide is what is typically called "Getting Started".
- Where's the list of conditions that are set when you power on?
- Where's the list of applications that are always running weather you touch them or not?
- What applications that come on the device that you cannot remove unless rooted can devour your available battery? (The only warning is Mobile Hotspot.)
- What is the method to reboot built into the OS ... you know like Ctrl-Alt-Del on a PC. (Is it really Power Off/Power On? Is it something else that is not documented?)
- There is one leaked "hidden menu" on the Bionic. Are there others?
</rant>
I think we need some REAL documentation.
... Thom
<rant>
</rant>
... Thom
