abhilashpujari
Hi,
i am working on android CTS test, i am getting API check time out error whenever i start test plan CTS, i followed the below steps for CTS test and also i mentioned my doubts.
CTS test steps :
1. Please download and install the Android 1.6 SDK on your machine.
2. Your phone should be running a user build (Android 1.6 and later) from
source.android.com
3. Please refer to this link on the Android developer site and set up your device
accordingly.
4. Make sure that your device has been flashed with a user build (Android 1.6 and
later) before you run CTS.
5. You need to download the TTS files via Settings > Speech synthesis > Install
voice data before running CTS tests. (Note that this assumes you have Android
Market installed on the device, if not you will need to install the files manually via
adb)
6. It is advisable to log in to the device with a test Google account, not an account
that you actually use.
7. Make sure the device has a SD card plugged in and the card is empty. Warning:
CTS may modify/erase data on the SD card plugged in to the device.
8. Do a factory data reset on the device (Settings > SD Card & phone storage >
Factory data reset). Warning: This will erase all user data from the phone.
9. Make sure no lock pattern is set on the device (Settings > Security & location >
Require Pattern should be unchecked.
Google Confidential
10. Make sure the "Screen Timeout" is set to "Never Timeout" (Settings > Sound &
Display > Screen Timeout should be set to "Never Timeout".
11. Make sure the "Stay Awake" development option is checked (Settings >
Applications > Development > Stay awake).
12. Make sure Settings > Application > Development > Allow mock locations is set
to true.
13. Make sure the device is at the home screen at the start of CTS (Press the home
button).
14. While a device is running tests, it must not be used for any other tasks.
15. Do not press any keys on the device while CTS is running. Pressing keys or
touching the screen of a test device will interfere with the running tests and may
lead to test failures.
doubts :
1) is it necessary to follow all the steps ?
2) for step 5, i copied the voice data to the SD card and if i follow step 8 it will erase all contents of SD card so how can i follow both step 5 and step 8 at a time...?
error message while doing CTS test on Device :
pvteam@pvteam-desktop:~/Desktop/android-cts/tools$ ./startcts
Android CTS version 2.1_pre_r1
Device(HT9A4LV00787) connected
cts_host > start --plan CTS
cts_host > There are 3 existing session(s) for plan CTS.
Create a new session or choose an existing one?
Create a new session [0]
Choose a session [1]
0
install met failure [install_failed_older_sdk]
start test plan CTS
CTS_INFO >>> Checking API...
CTS_INFO >>> This might take several minutes, please be patient...
uninstall met failure
API Check TIMEOUT.
(timeout)
CTS_INFO >>> Max ADB operations reached. Restarting ADB...
CTS_INFO >>> Restarting device ...
the Device restart took place three times then i stoped the CTS test, please give suggestions on this issue.
regards
Abhilash
CTS test steps :
source.android.com
accordingly.
adb)
Google Confidential
to true.
button).
doubts :
0
start test plan CTS
API Check TIMEOUT.
(timeout)
regards
Abhilash
