Registering to android market
M.Hazara
I have problem with xperia x8 and it says I can't loggin because of connection, but I clearly have internet connection. When I go to android market straight from internet, it works but still says "There are no Android devices associated with this account." Please help:confused:
Whereabouts are you located please?
There's a useful comment in the bug discussion:
1-go to key pad and enter *#06# it will show you the device IMEI number 2- write IMEI number on a piece of paper and keep it aside. 3- enter *#272* IMEI number # 4- Options will appear on the screen, choose the option XSG and press INSTALL 5- Your device will restart and "Market" will appear on the screen and in the Applications.
It seems to work for the few people who tried it and reported back afterwards.
What does the error message say in more detail? Does it sate something like "can't establish a secure connection"?
If so I suggest that you reinstall the phone software via Update Service. If you do not have Update Service installed on your PC you can download it from the website.
After reinstalling the software you enter your Google account details directly in the setup wizard that comes when you turn on the phone.
That should do it.
BR
Johan
