enby_dashie
A Phoenix Production
Android Forums Exclusive Release
#include <std/disclaimer.h>
* I am not responsible for bricked devices, dead SD cards, thermonuclear
* war, or the current economic crisis caused by you following these
* directions. YOU are choosing to make these modificiations, and
* if you point your finger at me for messing up your device, I will
* laugh at you.
This is ALPHA SOFTWARE,NO WARRANTIES WILL BE GIVEN
BLU View 2 Auto-Flasher
This flasher will backup your current stock firmware,unlock the bootloader,root
And update your phone to Sep 2021 security patch!
Download: https://www.mediafire.com/file/iplx8jqic57om54/autoflash.zip/file
Supported Operating systems
Arch Linux +derivatives
Debian+ Derivatives(currently untested,need testers)
Can add other distros,please see arch.sh or debian.sh to
see what packages need installed,and then supply the appropriate commands
be ready to test the script when i send you a test package!
Instructions:
make sure dialog is installed. the tool wont work without it!
open a terminal
unzip autoflash.zip
cd autoflash
bash start.sh
do the prep step for your os
DO NOT CONNECT YOUR DEVICE YET!
then choose dump and flash!
Connect your device while holding volume down
after that you will be returned to the main menu.
Select Exit if you are done.
Credits:
MTKClient: https://github.com/bkerler/mtkclient
Mediatek: For leaving gaping security holes yet again
Issues:
If flashing goes wrong,your backup is in ~/backup
issue the commands
cd ./resources
./mtk w boot ~/backup/boot.img
./mtk w super ~/backup/super.img
./mtk w vbmeta ~/backup/vbmeta.img
./mtk w recovery ~/backup/recovery.img
For any issues,Telegram contact is preferred(my username is in the readme)
I also will watch my androidforums PM,if nothing else to stay in compliance with forum guidelines
Known Bugs:
None afaik for Arch
Debian: script entirely broken,seems they handle pip differently. Working with another user to fix...
* laugh at you.
Instructions:
open a terminal
unzip autoflash.zip
cd autoflash
bash start.sh
Credits:
Issues:
issue the commands
cd ./resources
Known Bugs:
None afaik for Arch
