Root Rember diff? Well now I gotta use it.
EagerestWolf
Okay, so I will be posting a ton of Google Drive links over the next day or so. These are the diff files for my Cyanogenmod and the Stock Huawei system partition. This is going to be a long and tedious process of determining what to keep and what to chunk so any help is greatly appreciated.
NOTE: As I have a freshly built Cyanogenmod, I am not even gonna waste time with the app directory.
BIN: https://drive.google.com/file/d/0B_I4pF-Rn6C3ZzBKMnJOQzBzMGM/edit?usp=sharing
ETC: https://drive.google.com/file/d/0B_I4pF-Rn6C3OENGeHQydnJrUms/edit?usp=sharing
FONTS: https://drive.google.com/file/d/0B_I4pF-Rn6C3UkVXeFR6ZzVnZ3M/edit?usp=sharing
FRAMEWORK: https://drive.google.com/file/d/0B_I4pF-Rn6C3NmtGNlJDWjVIMkk/edit?usp=sharing
LIB (This one is CRITICAL): https://drive.google.com/file/d/0B_I4pF-Rn6C3TFNVTkFIQWxIQzg/edit?usp=sharing
MEDIA: https://drive.google.com/file/d/0B_I4pF-Rn6C3RXB5SGhudmZSZm8/edit?usp=sharing
USR: https://drive.google.com/file/d/0B_I4pF-Rn6C3YmR6Vmc0X0xHSWc/edit?usp=sharing
VENDOR: https://drive.google.com/file/d/0B_I4pF-Rn6C3M0x5UUowSmJ6MjQ/edit?usp=sharing
VERY IMPORTANT NOTE IF YOU CHOOSE TO HELP: THIS IS BASED ON "STOCK", SO PLEASE IGNORE ALL .DEX AND .ODEX FILES
I'm not trying to waste anyone's time.
Can someone link me up with more info on what is being done? In a way a n00b to android who wants to help would understand?
If not- no worries... don't want to get in the way.
The best thing a n00b can do is open each of the documents above and make note of everything that is in /mnt/system/* that is not in cm-10.1-y301a1/system/* (diff will say only in /mnt/system/*), and send that note one time as a message or share it as a Google doc.
Am i understanding you correct?
This is from the first link;
You want this:
Only in /mnt/system/bin: abtfilt
But ALL the lines that begin "Only in /mnt/ blah" ?
If I was right about what you wanted done, here is the first file you posted.
Only in /mnt/system/bin: akmd8963
Only in /mnt/system/bin: akmd8975
Only in /mnt/system/bin: amploader
Only in /mnt/system/bin: artagent
Only in /mnt/system/bin: ast-mm-vdec-omx-test7k
Only in /mnt/system/bin: ATFWD-daemon
Only in /mnt/system/bin: ath_supplicant
Only in /mnt/system/bin: athtestcmd
Only in /mnt/system/bin: atserver
Only in /mnt/system/bin: bluetoothd
Only in /mnt/system/bin: bootanimationex
Only in /mnt/system/bin: brcm_patchram_plus
Only in /mnt/system/bin: brcm_patchram_plus_check
Only in /mnt/system/bin: bridgemgrd
Only in /mnt/system/bin: bt_check
Only in /mnt/system/bin: btld
Only in /mnt/system/bin: callife
Only in /mnt/system/bin: cat
Only in /mnt/system/bin: charge
Only in /mnt/system/bin: chargelogcat
Only in /mnt/system/bin: chmod
Only in /mnt/system/bin: chown
Only in /mnt/system/bin: cmp
Only in /mnt/system/bin: cnd
Only in /mnt/system/bin: curl
Only in /mnt/system/bin: cust
Only in /mnt/system/bin: date
Only in /mnt/system/bin: dbox
Only in /mnt/system/bin: dd
Only in /mnt/system/bin: df
Only in /mnt/system/bin: dhd
Only in /mnt/system/bin: diag_dci_client
Only in /mnt/system/bin: diag_mdlog
Only in /mnt/system/bin: diag_socket_log
Only in /mnt/system/bin: diag_uart_log
Only in /mnt/system/bin: dmesg
Only in /mnt/system/bin: ds_fmc_appd
Only in /mnt/system/bin: dump_debug
Only in /mnt/system/bin: dumptool
Only in /mnt/system/bin: dun-server
Only in /mnt/system/bin: .ext
Only in /mnt/system/bin: filebackup
Only in /mnt/system/bin: fmconfig
Only in /mnt/system/bin: ftmdaemon
Only in /mnt/system/bin: getevent
Only in /mnt/system/bin: getprop
Only in /mnt/system/bin: gps_check
Only in /mnt/system/bin: gpu_dcvsd
Only in /mnt/system/bin: hciattach
Only in /mnt/system/bin: hciattach_check
Only in /mnt/system/bin: hci_dev_state
Only in /mnt/system/bin: hd
Only in /mnt/system/bin: hostapd
Only in /mnt/system/bin: hostapd_cli
Only in /mnt/system/bin: hwdevctlservice
Only in /mnt/system/bin: hw_scsi_switch
Only in /mnt/system/bin: id
Only in /mnt/system/bin: ifconfig
Only in /mnt/system/bin: iftop
Only in /mnt/system/bin: insmod
Only in /mnt/system/bin: ioctl
Only in /mnt/system/bin: ionice
Only in /mnt/system/bin: iperf
Only in /mnt/system/bin: ipth_dua
Only in /mnt/system/bin: iw
Only in /mnt/system/bin: kill
Only in /mnt/system/bin: kmsgcat
Only in /mnt/system/bin: ln
Only in /mnt/system/bin: load_oemlogo
Only in /mnt/system/bin: loc_api_app
Only in /mnt/system/bin: log
Only in /mnt/system/bin: ls
Only in /mnt/system/bin: lsmod
Only in /mnt/system/bin: lsof
Only in /mnt/system/bin: md5
Only in /mnt/system/bin: mkdir
Only in /mnt/system/bin: mm-adec-omxaac-test
Only in /mnt/system/bin: mm-adec-omxadpcm-test
Only in /mnt/system/bin: mm-adec-omxamr-test
Only in /mnt/system/bin: mm-adec-omxamrwb-test
Only in /mnt/system/bin: mm-adec-omxevrc-hw-test
Only in /mnt/system/bin: mm-adec-omxmp3-test
Only in /mnt/system/bin: mm-adec-omxQcelpHw-test
Only in /mnt/system/bin: mm-adec-omxvam-test
Only in /mnt/system/bin: mm-adec-omxwma-test
Only in /mnt/system/bin: mm-adspsvc-test
Only in /mnt/system/bin: mm-aenc-omxaac-test
Only in /mnt/system/bin: mm-aenc-omxamr-test
Only in /mnt/system/bin: mm-aenc-omxevrc-test
Only in /mnt/system/bin: mm-aenc-omxqcelp13-test
Only in /mnt/system/bin: mm-audio-alsa-test
Only in /mnt/system/bin: mm-audio-ctrl-test
Only in /mnt/system/bin: mm-audio-mvs-test
Only in /mnt/system/bin: mm-jpeg-dec-test
Only in /mnt/system/bin: mm-jpeg-enc-test
Only in /mnt/system/bin: mm-jpeg-enc-test-client
Only in /mnt/system/bin: mm-pp-daemon
Only in /mnt/system/bin: mm-qcamera-daemon
Only in /mnt/system/bin: mm-qcamera-test
Only in /mnt/system/bin: mm-qcamera-testsuite-client
Only in /mnt/system/bin: mm-vdec-omx-test
Only in /mnt/system/bin: mm-venc-omx-test
Only in /mnt/system/bin: modempre
Only in /mnt/system/bin: mount
Only in /mnt/system/bin: mpdecision
Only in /mnt/system/bin: mtk_cmux
Only in /mnt/system/bin: mv
Only in /mnt/system/bin: nandread
Only in /mnt/system/bin: netmgrd
Only in /mnt/system/bin: netstat
Only in /mnt/system/bin: newfs_msdos
Only in /mnt/system/bin: nfc_check
Only in /mnt/system/bin: nl_listener
Only in /mnt/system/bin: notify
Only in /mnt/system/bin: n_smux
Only in /mnt/system/bin: nvext
Only in /mnt/system/bin: oeminfo_test
Only in /mnt/system/bin: oem_rpc_svc
Only in /mnt/system/bin: pand
Only in /mnt/system/bin: pcscd
Only in /mnt/system/bin: port-bridge
Only in /mnt/system/bin: printenv
Only in /mnt/system/bin: ps
Only in /mnt/system/bin: psatUtil
Only in /mnt/system/bin: qmiproxy
Only in /mnt/system/bin: qmuxd
Only in /mnt/system/bin: qosmgr
Only in /mnt/system/bin: qrngd
Only in /mnt/system/bin: qrngtest
Only in /mnt/system/bin: radish
Only in /mnt/system/bin: reboot
Only in /mnt/system/bin: rebootmgr
Only in /mnt/system/bin: renice
Only in /mnt/system/bin: rm
Only in /mnt/system/bin: rmdir
Only in /mnt/system/bin: rmmod
Only in /mnt/system/bin: rmt_oeminfo
Only in /mnt/system/bin: rmt_storage
Only in /mnt/system/bin: route
Only in /mnt/system/bin: sapd
Only in /mnt/system/bin: schedtop
Only in /mnt/system/bin: sdptool
Only in /mnt/system/bin: sendevent
Only in /mnt/system/bin: setconsole
Only in /mnt/system/bin: setprop
Only in /mnt/system/bin: setup_fs
Only in /mnt/system/bin: sh
Only in /mnt/system/bin: shutdownanimation
Only in /mnt/system/bin: sleep
Only in /mnt/system/bin: sleeplogcat
Only in /mnt/system/bin: smd
Only in /mnt/system/bin: start
Only in /mnt/system/bin: stop
Only in /mnt/system/bin: subsystem_ramdump
Only in /mnt/system/bin: sync
Only in /mnt/system/bin: test_diag
Only in /mnt/system/bin: test_gemini
Only in /mnt/system/bin: testpcsc
Only in /mnt/system/bin: testpcsc_sendapdu
Only in /mnt/system/bin: thermald
Only in /mnt/system/bin: top
Only in /mnt/system/bin: touch
Only in /mnt/system/bin: umount
Only in /mnt/system/bin: uptime
Only in /mnt/system/bin: usbhub
Only in /mnt/system/bin: usbhub_init
Only in /mnt/system/bin: v4l2-qcamera-app
Only in /mnt/system/bin: vmstat
Only in /mnt/system/bin: watchprops
Only in /mnt/system/bin: widevinetest_rpc
Only in /mnt/system/bin: wipe
Only in /mnt/system/bin: wiperiface
Only in /mnt/system/bin: wiperiface_v01
Only in /mnt/system/bin: wl
Only in /mnt/system/bin: wl_4330
Only in /mnt/system/bin: wlan_detect
Only in /mnt/system/bin: wmiconfig
Only in /mnt/system/bin: wpa_cli
Only in /mnt/system/bin: wpa_supplicant
Only in /mnt/system/bin: write_NV_114
Total of 181 files only in /mnt/system/*
2nd file; etc
diff_etc.txt (105 hits)
Line 1: Only in /mnt/system/etc: amzn.mshop.properties
Line 4: Only in /mnt/system/etc: AudioFilter.csv
Line 5: Only in /mnt/system/etc: AudioFilter_MSM7225A_U8185.csv
Line 6: Only in /mnt/system/etc: AudioFilter_MSM7225A_U8655.csv
Line 7: Only in /mnt/system/etc: AudioFilter_MSM7225A_U8655.VerE.csv
Line 8: Only in /mnt/system/etc: AudioFilter_MSM7225A_U8661.csv
Line 9: Only in /mnt/system/etc: AudioFilter_MSM7225A_U8665.csv
Line 10: Only in /mnt/system/etc: AudioFilter_MSM7227A_U8815.csv
Line 11: Only in /mnt/system/etc: AudioFilter_MSM7227A_U8815.VerE.csv
Line 12: Only in /mnt/system/etc: AudioFilter_MSM7625A_C8655.csv
Line 13: Only in /mnt/system/etc: AudioFilter_MSM7625A_M660.csv
Line 14: Only in /mnt/system/etc: AudioFilter_MSM8X25_C8812P.csv
Line 15: Only in /mnt/system/etc: AudioFilter_MSM8X25_C8825D.csv
Line 16: Only in /mnt/system/etc: AudioFilter_MSM8X25_C8950D.csv
Line 17: Only in /mnt/system/etc: AudioFilter_MSM8X25_U8825.csv
Line 18: Only in /mnt/system/etc: AudioFilter_MSM8X25_U8825D.csv
Line 19: Only in /mnt/system/etc: AudioFilter_MSM8X25_U8950.csv
Line 20: Only in /mnt/system/etc: AudioFilter_MSM8X25_U8950D.csv
Line 23: Only in /mnt/system/etc/bluetooth: audio.conf
Line 25: Only in /mnt/system/etc/bluetooth: auto_pairing.conf
Line 26: Only in /mnt/system/etc/bluetooth: BCM4329B1_HW.hcd
Line 27: Only in /mnt/system/etc/bluetooth: BCM4329_check.hcd
Line 28: Only in /mnt/system/etc/bluetooth: BCM4330B1_1025_Huawei_H8686.hcd
Line 29: Only in /mnt/system/etc/bluetooth: BCM4330_check.hcd
Line 30: Only in /mnt/system/etc/bluetooth: BCM4330.hcd
Line 31: Only in /mnt/system/etc/bluetooth: blacklist.conf
Line 34: Only in /mnt/system/etc/bluetooth: did.conf
Line 35: Only in /mnt/system/etc/bluetooth: init.bcm.bt.sh
Line 36: Only in /mnt/system/etc/bluetooth: init.bcm.chip_off.sh
Line 37: Only in /mnt/system/etc/bluetooth: init.bcm.chip_on.sh
Line 38: Only in /mnt/system/etc/bluetooth: input.conf
Line 39: Only in /mnt/system/etc/bluetooth: iop_device_list.conf
Line 40: Only in /mnt/system/etc/bluetooth: network.conf
Line 41: Only in /mnt/system/etc: cdrom_install.iso
Line 43: Only in /mnt/system/etc/dhcpcd: dhcpcd.conf
Line 45: Only in /mnt/system/etc: external_sd.fstab
Line 46: Only in /mnt/system/etc: fallback_fonts-ja.xml
Line 48: Only in /mnt/system/etc: fir_filter
Line 49: Only in /mnt/system/etc: firmware
Line 52: Only in /mnt/system/etc: init.ath3k.bt.sh
Line 54: Only in /mnt/system/etc: init.qcom.bt.sh
Line 55: Only in /mnt/system/etc: init.qcom.coex.sh
Line 56: Only in /mnt/system/etc: init.qcom.composition_type.sh
Line 57: Only in /mnt/system/etc: init.qcom.efs.sync.sh
Line 58: Only in /mnt/system/etc: init.qcom.fm.sh
Line 59: Only in /mnt/system/etc: init.qcom.post_boot.sh
Line 60: Only in /mnt/system/etc: init.qcom.post_fs.sh
Line 61: Only in /mnt/system/etc: init.qcom.sdio.sh
Line 62: Only in /mnt/system/etc: init.qcom.thermald_conf.sh
Line 63: Only in /mnt/system/etc: init.qcom.wifi.sh
Line 64: Only in /mnt/system/etc: init.target.8x25.sh
Line 65: Only in /mnt/system/etc: internal_sd.fstab
Line 66: Only in /mnt/system/etc: loc_parameter.ini
Line 71: Only in /mnt/system/etc: nfcee_access.xml
Line 73: Only in /mnt/system/etc: OperatorPolicy.xml
Line 74: Only in /mnt/system/etc/permissions: android.hardware.audio.low_latency.xml
Line 75: Only in /mnt/system/etc/permissions: android.hardware.bluetooth.xml
Line 76: Only in /mnt/system/etc/permissions: android.hardware.camera.xml
Line 77: Only in /mnt/system/etc/permissions: android.hardware.faketouch.multitouch.distinct.xml
Line 78: Only in /mnt/system/etc/permissions: android.hardware.faketouch.multitouch.jazzhand.xml
Line 79: Only in /mnt/system/etc/permissions: android.hardware.faketouch.xml
Line 80: Only in /mnt/system/etc/permissions: android.hardware.location.gps.xml
Line 81: Only in /mnt/system/etc/permissions: android.hardware.location.xml
Line 82: Only in /mnt/system/etc/permissions: android.hardware.microphone.xml
Line 83: Only in /mnt/system/etc/permissions: android.hardware.sensor.accelerometer.xml
Line 84: Only in /mnt/system/etc/permissions: android.hardware.sensor.compass.xml
Line 85: Only in /mnt/system/etc/permissions: android.hardware.sensor.light.xml
Line 86: Only in /mnt/system/etc/permissions: android.hardware.sensor.proximity.xml
Line 87: Only in /mnt/system/etc/permissions: android.hardware.telephony.gsm.xml
Line 88: Only in /mnt/system/etc/permissions: android.hardware.touchscreen.multitouch.distinct.xml
Line 89: Only in /mnt/system/etc/permissions: android.hardware.touchscreen.multitouch.jazzhand.xml
Line 90: Only in /mnt/system/etc/permissions: android.hardware.touchscreen.multitouch.xml
Line 91: Only in /mnt/system/etc/permissions: android.hardware.touchscreen.xml
Line 92: Only in /mnt/system/etc/permissions: android.hardware.usb.accessory.xml
Line 93: Only in /mnt/system/etc/permissions: android.hardware.usb.host.xml
Line 94: Only in /mnt/system/etc/permissions: android.hardware.wifi.direct.xml
Line 95: Only in /mnt/system/etc/permissions: android.hardware.wifi.xml
Line 96: Only in /mnt/system/etc/permissions: android.software.livewallpaper.xml
Line 98: Only in /mnt/system/etc/permissions: com.broadcom.bt.le.xml
Line 99: Only in /mnt/system/etc/permissions: com.broadcom.bt.xml
Line 100: Only in /mnt/system/etc/permissions: com.cequint.platform.xml
Line 102: Only in /mnt/system/etc/permissions: com.google.android.maps.xml
Line 103: Only in /mnt/system/etc/permissions: com.google.android.media.effects.xml
Line 104: Only in /mnt/system/etc/permissions: com.google.widevine.software.drm.xml
Line 105: Only in /mnt/system/etc/permissions: com.qualcomm.location.vzw_library.xml
Line 107: Only in /mnt/system/etc/permissions: gba-service-lib.xml
Line 108: Only in /mnt/system/etc/permissions: handheld_core_hardware.xml
Line 109: Only in /mnt/system/etc/permissions: hwframework.xml
Line 110: Only in /mnt/system/etc/permissions: jsr-api.xml
Line 111: Only in /mnt/system/etc/permissions: org.simalliance.openmobileapi.xml
Line 113: Only in /mnt/system/etc/permissions: qcnvitems.xml
Line 114: Only in /mnt/system/etc/permissions: qcrilhook.xml
Line 116: Only in /mnt/system/etc: process_bl.xml
Line 117: Only in /mnt/system/etc: qosmgr_rules.xml
Line 118: Only in /mnt/system/etc: reader.conf
Line 120: Only in /mnt/system/etc: resolv.conf
Line 121: Only in /mnt/system/etc: revoke_internet_apk.list
Line 128: Only in /mnt/system/etc: thermald-8x25-msm1-pmic_therm.conf
Line 129: Only in /mnt/system/etc: thermald.conf
Line 130: Only in /mnt/system/etc: thermald-Y300-J1.conf
Line 131: Only in /mnt/system/etc: updatecmds
Line 132: Only in /mnt/system/etc: UserPolicy.xml
Line 134: Only in /mnt/system/etc: vold.fstab
Line 135: Only in /mnt/system/etc: wifi
Line 136: Only in /mnt/system/etc: wiperconfig.xml
diff_fonts.txt (4 hits)
Line 5: Only in /mnt/system/fonts: DroidSans-Bold.ttf
Line 6: Only in /mnt/system/fonts: DroidSansChinese.ttf
Line 10: Only in /mnt/system/fonts: DroidSans.ttf
Line 27: Only in /mnt/system/fonts: Roboto-Medium.ttf
I've manually removed the lines that ended in odex
Still don't know if this is correct/what you need...
diff_framework.txt (59 hits)
Line 17: Only in /mnt/system/framework: com.broadcom.bt.jar
Line 18: Only in /mnt/system/framework: com.broadcom.bt.le.jar
Line 21: Only in /mnt/system/framework: com.cequint.platform.jar
Line 23: Only in /mnt/system/framework: com.google.android.maps.jar
Line 25: Only in /mnt/system/framework: com.google.android.media.effects.jar
Line 27: Only in /mnt/system/framework: com.google.widevine.software.drm.jar
Line 29: Only in /mnt/system/framework: com.qualcomm.location.vzw_library.jar
Line 31: Only in /mnt/system/framework: com.quicinc.cne.jar
Line 41: Only in /mnt/system/framework: framework_ext.jar
Line 46: Only in /mnt/system/framework: framework-res-hwext.apk
Line 49: Only in /mnt/system/framework: gba-service-lib.jar
Line 51: Only in /mnt/system/framework: hwframework.jar
Line 59: Only in /mnt/system/framework: jsr-api.jar
Line 62: Only in /mnt/system/framework: modemwarmup.jar
Line 66: Only in /mnt/system/framework: org.codeaurora.Performance.jar
Line 68: Only in /mnt/system/framework: org.simalliance.openmobileapi.jar
Line 72: Only in /mnt/system/framework: qcnvitems.jar
Line 74: Only in /mnt/system/framework: qcrilhook.jar
diff_lib.txt (298 hits)
Line 1: Only in /mnt/system/lib: bluez-plugin
Line 4: Only in /mnt/system/lib/drm: libdrmhwomavoneplugin.so
Line 5: Only in /mnt/system/lib/drm: libdrmwvmplugin.so
Line 7: Only in /mnt/system/lib/egl: egl.cfg
Line 8: Only in /mnt/system/lib/egl: eglsubAndroid.so
Line 9: Only in /mnt/system/lib/egl: libEGL_adreno200.so
Line 11: Only in /mnt/system/lib/egl: libGLESv1_CM_adreno200.so
Line 12: Only in /mnt/system/lib/egl: libGLESv2_adreno200.so
Line 13: Only in /mnt/system/lib/egl: libq3dtools_adreno200.so
Line 14: Only in /mnt/system/lib: hciutils.so
Line 15: Only in /mnt/system/lib/hw: audio.a2dp.default.so
Line 17: Only in /mnt/system/lib/hw: audio_policy.msm7627a.so
Line 20: Only in /mnt/system/lib/hw: audio.primary.msm7627a.so
Line 22: Only in /mnt/system/lib/hw: camera.msm7627a.so
Line 23: Only in /mnt/system/lib/hw: copybit.msm7627a.so
Line 24: Only in /mnt/system/lib/hw: gps.default.so
Line 26: Only in /mnt/system/lib/hw: gralloc.msm7627a.so
Line 27: Only in /mnt/system/lib/hw: hwcomposer.msm7627a.so
Line 29: Only in /mnt/system/lib/hw: libbcmfm_if.so
Line 30: Only in /mnt/system/lib/hw: lights.msm7627a.so
Line 32: Only in /mnt/system/lib/hw: nfc.huawei.so
Line 35: Only in /mnt/system/lib/hw: sensors.default.so
Line 36: Only in /mnt/system/lib: libaah_rtp.so
Line 37: Only in /mnt/system/lib: libadc.so
Line 38: Only in /mnt/system/lib: libagpstools.so
Line 39: Only in /mnt/system/lib: liballjoyn.so
Line 45: Only in /mnt/system/lib: libAppDataSearch.so
Line 46: Only in /mnt/system/lib: libassd.so
Line 47: Only in /mnt/system/lib: libaudcal.so
Line 48: Only in /mnt/system/lib: libaudioalsa.so
Line 50: Only in /mnt/system/lib: libaudioeq.so
Line 52: Only in /mnt/system/lib: libaudioparameter.so
Line 54: Only in /mnt/system/lib: libauth.so
Line 57: Only in /mnt/system/lib: libbcc.so.sha1
Line 59: Only in /mnt/system/lib: libbcm_fm_power.so
Line 61: Only in /mnt/system/lib: libbluedroid.so
Line 62: Only in /mnt/system/lib: libbluetoothd.so
Line 64: Only in /mnt/system/lib: libbluetooth.so
Line 65: Only in /mnt/system/lib: libbson.so
Line 67: Only in /mnt/system/lib: libbtio.so
Line 68: Only in /mnt/system/lib: libbt.so
Line 69: Only in /mnt/system/lib: libbtsvc.so
Line 74: Only in /mnt/system/lib: libchip_management.so
Line 75: Only in /mnt/system/lib: libchromatix_hi542_default_video.so
Line 76: Only in /mnt/system/lib: libchromatix_hi542_preview.so
Line 77: Only in /mnt/system/lib: libchromatix_imx074_default_video.so
Line 78: Only in /mnt/system/lib: libchromatix_imx074_preview.so
Line 79: Only in /mnt/system/lib: libchromatix_imx074_video_hd.so
Line 80: Only in /mnt/system/lib: libchromatix_imx074_zsl.so
Line 81: Only in /mnt/system/lib: libchromatix_imx091_default_video.so
Line 82: Only in /mnt/system/lib: libchromatix_imx091_preview.so
Line 83: Only in /mnt/system/lib: libchromatix_imx091_video_hd.so
Line 84: Only in /mnt/system/lib: libchromatix_imx105_sunny_default_video.so
Line 85: Only in /mnt/system/lib: libchromatix_imx105_sunny_preview.so
Line 86: Only in /mnt/system/lib: libchromatix_mt9e013_default_video.so
Line 87: Only in /mnt/system/lib: libchromatix_mt9e013_preview.so
Line 88: Only in /mnt/system/lib: libchromatix_mt9e013_sunny_default_video.so
Line 89: Only in /mnt/system/lib: libchromatix_mt9e013_sunny_preview.so
Line 90: Only in /mnt/system/lib: libchromatix_mt9e013_sunny_video_hfr.so
Line 91: Only in /mnt/system/lib: libchromatix_mt9e013_video_hfr.so
Line 92: Only in /mnt/system/lib: libchromatix_mt9p017_default_video.so
Line 93: Only in /mnt/system/lib: libchromatix_mt9p017_preview.so
Line 94: Only in /mnt/system/lib: libchromatix_ov2720_default_video.so
Line 95: Only in /mnt/system/lib: libchromatix_ov2720_hfr.so
Line 96: Only in /mnt/system/lib: libchromatix_ov2720_preview.so
Line 97: Only in /mnt/system/lib: libchromatix_ov2720_zsl.so
Line 98: Only in /mnt/system/lib: libchromatix_ov5647_default_video.so
Line 99: Only in /mnt/system/lib: libchromatix_ov5647_ff_default_video.so
Line 100: Only in /mnt/system/lib: libchromatix_ov5647_ff_preview.so
Line 101: Only in /mnt/system/lib: libchromatix_ov5647_ff_video_hfr.so
Line 102: Only in /mnt/system/lib: libchromatix_ov5647_preview.so
Line 103: Only in /mnt/system/lib: libchromatix_ov5647_video_hfr.so
Line 104: Only in /mnt/system/lib: libchromatix_ov5647_y300_default_video.so
Line 105: Only in /mnt/system/lib: libchromatix_ov5647_y300_preview.so
Line 106: Only in /mnt/system/lib: libchromatix_ov8825_default_video.so
Line 107: Only in /mnt/system/lib: libchromatix_ov8825_preview.so
Line 108: Only in /mnt/system/lib: libchromatix_ov9726_default_video.so
Line 109: Only in /mnt/system/lib: libchromatix_ov9726_preview.so
Line 110: Only in /mnt/system/lib: libchromatix_s5k3h2_default_video.so
Line 111: Only in /mnt/system/lib: libchromatix_s5k3h2_preview.so
Line 112: Only in /mnt/system/lib: libchromatix_s5k3l1yx_default_video.so
Line 113: Only in /mnt/system/lib: libchromatix_s5k3l1yx_hfr_120fps.so
Line 114: Only in /mnt/system/lib: libchromatix_s5k3l1yx_hfr_60fps.so
Line 115: Only in /mnt/system/lib: libchromatix_s5k3l1yx_hfr_90fps.so
Line 116: Only in /mnt/system/lib: libchromatix_s5k3l1yx_preview.so
Line 117: Only in /mnt/system/lib: libchromatix_s5k3l1yx_video_hd.so
Line 118: Only in /mnt/system/lib: libchromatix_s5k3l1yx_zsl.so
Line 119: Only in /mnt/system/lib: libchromatix_s5k4e1_3_default_video.so
Line 120: Only in /mnt/system/lib: libchromatix_s5k4e1_3_preview.so
Line 121: Only in /mnt/system/lib: libchromatix_s5k4e1_3_y300_default_video.so
Line 122: Only in /mnt/system/lib: libchromatix_s5k4e1_3_y300_preview.so
Line 123: Only in /mnt/system/lib: libchromatix_s5k4e1_default_video.so
Line 124: Only in /mnt/system/lib: libchromatix_s5k4e1_f_default_video.so
Line 125: Only in /mnt/system/lib: libchromatix_s5k4e1_f_preview.so
Line 126: Only in /mnt/system/lib: libchromatix_s5k4e1_preview.so
Line 127: Only in /mnt/system/lib: libchromatix_vx6953_default_video.so
Line 128: Only in /mnt/system/lib: libchromatix_vx6953_preview.so
Line 129: Only in /mnt/system/lib: libchromeview.so
Line 135: Only in /mnt/system/lib: libcm.so
Line 136: Only in /mnt/system/lib: libcneapiclient.so
Line 137: Only in /mnt/system/lib: libcnefeatureconfig.so
Line 138: Only in /mnt/system/lib: libcneqmiutils.so
Line 139: Only in /mnt/system/lib: libcneutils.so
Line 140: Only in /mnt/system/lib: libCommandSvc.so
Line 141: Only in /mnt/system/lib: libcommondefs.so
Line 143: Only in /mnt/system/lib: libconfigdb.so
Line 144: Only in /mnt/system/lib: libcontrast.so
Line 149: Only in /mnt/system/lib: libcurl.so
Line 153: Only in /mnt/system/lib: libDiagService.so
Line 154: Only in /mnt/system/lib: libdiag.so
Line 156: Only in /mnt/system/lib: libdivxdrmdecrypt.so
Line 157: Only in /mnt/system/lib: libDivxDrm.so
Line 159: Only in /mnt/system/lib: libdme_main.so
Line 160: Only in /mnt/system/lib: libdnshostprio.so
Line 165: Only in /mnt/system/lib: libdsi_netctrl.so
Line 166: Only in /mnt/system/lib: libdsm.so
Line 167: Only in /mnt/system/lib: libdsprofile.so
Line 168: Only in /mnt/system/lib: libdss.so
Line 169: Only in /mnt/system/lib: libdsucsd.so
Line 170: Only in /mnt/system/lib: libdsutils.so
Line 171: Only in /mnt/system/lib: libdualsimswitch.so
Line 187: Only in /mnt/system/lib: libfacelock_jni.so
Line 188: Only in /mnt/system/lib: libfastcvopt.so
Line 191: Only in /mnt/system/lib: libfilterpack_facedetect.so
Line 193: Only in /mnt/system/lib: libfilters.so
Line 194: Only in /mnt/system/lib: libfm_common_hal.so
Line 195: Only in /mnt/system/lib: libfm_hal.so
Line 196: Only in /mnt/system/lib: libfm_jni.so
Line 197: Only in /mnt/system/lib: libfm_volume.so
Line 198: Only in /mnt/system/lib: libfrsdk.so
Line 201: Only in /mnt/system/lib: libgcomm_jni.so
Line 202: Only in /mnt/system/lib: libgemini.so
Line 203: Only in /mnt/system/lib: libgenlock.so
Line 204: Only in /mnt/system/lib: libgesture_client.so
Line 205: Only in /mnt/system/lib: libgestureservice.so
Line 206: Only in /mnt/system/lib: libgetzip.so
Line 210: Only in /mnt/system/lib: libglib.so
Line 211: Only in /mnt/system/lib: libgoggles_clientvision.so
Line 212: Only in /mnt/system/lib: libgoogle_recognizer_jni_l.so
Line 213: Only in /mnt/system/lib: libgps.so
Line 214: Only in /mnt/system/lib: libgps.utils.so
Line 215: Only in /mnt/system/lib: libgsdi_exp.so
Line 216: Only in /mnt/system/lib: libgsl.so
Line 217: Only in /mnt/system/lib: libgstk_exp.so
Line 222: Only in /mnt/system/lib: libhdr.so
Line 223: Only in /mnt/system/lib: libhwcexternal.so
Line 224: Only in /mnt/system/lib: libHWColorPen.so
Line 225: Only in /mnt/system/lib: libhwcservice.so
Line 226: Only in /mnt/system/lib: libhwdevctl_client.so
Line 227: Only in /mnt/system/lib: libhwdevctlservice.so
Line 228: Only in /mnt/system/lib: libhw_flashlight.so
Line 229: Only in /mnt/system/lib: libhwnv.so
Line 230: Only in /mnt/system/lib: libhwrpc.so
Line 231: Only in /mnt/system/lib: libhwtransfer.so
Line 232: Only in /mnt/system/lib: libhwui.so
Line 233: Only in /mnt/system/lib: libI420colorconvert.so
Line 236: Only in /mnt/system/lib: libidl.so
Line 237: Only in /mnt/system/lib: libifdsmartcardapi.so
Line 238: Only in /mnt/system/lib: libimage-jpeg-enc-omx-comp.so
Line 239: Only in /mnt/system/lib: libimage-omx-common.so
Line 240: Only in /mnt/system/lib: libinputcore-2.so
Line 248: Only in /mnt/system/lib: libjni_hwime.so
Line 249: Only in /mnt/system/lib: libjni_hw_mosaic.so
Line 250: Only in /mnt/system/lib: libjni_latinimegoogle.so
Line 253: Only in /mnt/system/lib: libjni_pinyinime.so
Line 256: Only in /mnt/system/lib: liblasic.so
Line 257: Only in /mnt/system/lib: libloc_adapter.so
Line 258: Only in /mnt/system/lib: libloc_api-rpc-qc.so
Line 259: Only in /mnt/system/lib: libloc_eng.so
Line 260: Only in /mnt/system/lib: libloc_ext.so
Line 268: Only in /mnt/system/lib: libmemalloc.so
Line 269: Only in /mnt/system/lib: libmm-abl-oem.so
Line 270: Only in /mnt/system/lib: libmm-abl.so
Line 271: Only in /mnt/system/lib: libmm-adspsvc.so
Line 272: Only in /mnt/system/lib: libmm-audio-resampler.so
Line 273: Only in /mnt/system/lib: libmmcamera_faceproc.so
Line 274: Only in /mnt/system/lib: libmmcamera_frameproc.so
Line 275: Only in /mnt/system/lib: libmmcamera_hdr_lib.so
Line 276: Only in /mnt/system/lib: libmmcamera_image_stab.so
Line 277: Only in /mnt/system/lib: libmmcamera_interface2.so
Line 278: Only in /mnt/system/lib: libmmcamera_statsproc31.so
Line 279: Only in /mnt/system/lib: libmmcamera_wavelet_lib.so
Line 280: Only in /mnt/system/lib: libmmgsdilib.so
Line 281: Only in /mnt/system/lib: libmmipl.so
Line 282: Only in /mnt/system/lib: libmmirunning.so
Line 283: Only in /mnt/system/lib: libmmitest.so
Line 284: Only in /mnt/system/lib: libmmjpeg.so
Line 285: Only in /mnt/system/lib: libmm-omxcore.so
Line 286: Only in /mnt/system/lib: libmmosal.so
Line 287: Only in /mnt/system/lib: libmmparser.so
Line 288: Only in /mnt/system/lib: libmmrtpdecoder.so
Line 289: Only in /mnt/system/lib: libmmstillomx.so
Line 290: Only in /mnt/system/lib: libmomedia_audio_jni.so
Line 293: Only in /mnt/system/lib: libmvs.so
Line 298: Only in /mnt/system/lib: libnetmgr.so
Line 300: Only in /mnt/system/lib: libnfc_jni.so
Line 302: Only in /mnt/system/lib: libnfc.so
Line 303: Only in /mnt/system/lib: libNimsWrap.so
Line 304: Only in /mnt/system/lib: libnl_2.so
Line 305: Only in /mnt/system/lib: libnmc.so
Line 306: Only in /mnt/system/lib: libnmsp_speex.so
Line 307: Only in /mnt/system/lib: libnv.so
Line 308: Only in /mnt/system/lib: liboemcamera.so
Line 309: Only in /mnt/system/lib: liboeminfodata.so
Line 310: Only in /mnt/system/lib: liboeminfo.so
Line 311: Only in /mnt/system/lib: liboem_rapi.so
Line 312: Only in /mnt/system/lib: libOmxAacDec.so
Line 313: Only in /mnt/system/lib: libOmxAacEnc.so
Line 314: Only in /mnt/system/lib: libOmxAc3HwDec.so
Line 315: Only in /mnt/system/lib: libOmxAdpcmDec.so
Line 316: Only in /mnt/system/lib: libOmxAmrDec.so
Line 317: Only in /mnt/system/lib: libOmxAmrEnc.so
Line 318: Only in /mnt/system/lib: libOmxAmrRtpDec.so
Line 319: Only in /mnt/system/lib: libOmxAmrwbDec.so
Line 320: Only in /mnt/system/lib: libOmxCore.so
Line 321: Only in /mnt/system/lib: libOmxEvrcDec.so
Line 322: Only in /mnt/system/lib: libOmxEvrcEnc.so
Line 323: Only in /mnt/system/lib: libOmxEvrcHwDec.so
Line 324: Only in /mnt/system/lib: libOmxH264Dec.so
Line 325: Only in /mnt/system/lib: libOmxIttiamVdec.so
Line 326: Only in /mnt/system/lib: libOmxIttiamVenc.so
Line 327: Only in /mnt/system/lib: libOmxMp3Dec.so
Line 328: Only in /mnt/system/lib: libOmxMpeg4Dec.so
Line 329: Only in /mnt/system/lib: libOmxOn2Dec.so
Line 330: Only in /mnt/system/lib: libOmxQcelp13Dec.so
Line 331: Only in /mnt/system/lib: libOmxQcelp13Enc.so
Line 332: Only in /mnt/system/lib: libOmxQcelpHwDec.so
Line 333: Only in /mnt/system/lib: libOmxrv9Dec.so
Line 334: Only in /mnt/system/lib: libOmxVidEnc.so
Line 335: Only in /mnt/system/lib: libOmxVp8Dec.so
Line 336: Only in /mnt/system/lib: libOmxWmaDec.so
Line 337: Only in /mnt/system/lib: libOmxWmvDec.so
Line 338: Only in /mnt/system/lib: liboncrpc.so
Line 341: Only in /mnt/system/lib: libOpenVG.so
Line 342: Only in /mnt/system/lib: libortp_center.so
Line 343: Only in /mnt/system/lib: libortp.so
Line 344: Only in /mnt/system/lib: liboverlay.so
Line 346: Only in /mnt/system/lib: libpbmlib.so
Line 347: Only in /mnt/system/lib: libpcsclite.so
Line 348: Only in /mnt/system/lib: libping_mdm.so
Line 350: Only in /mnt/system/lib: libpn544_fw.so
Line 351: Only in /mnt/system/lib: libpng.so
Line 355: Only in /mnt/system/lib: libproduct_bt_check.so
Line 356: Only in /mnt/system/lib: libprojectmenu.so
Line 357: Only in /mnt/system/lib: libqcci_legacy.so
Line 358: Only in /mnt/system/lib: libqc-opt.so
Line 359: Only in /mnt/system/lib: libqdi.so
Line 360: Only in /mnt/system/lib: libqdMetaData.so
Line 361: Only in /mnt/system/lib: libqdp.so
Line 362: Only in /mnt/system/lib: libqdutils.so
Line 363: Only in /mnt/system/lib: libqmi_client_qmux.so
Line 364: Only in /mnt/system/lib: libqmi_csvt_srvc.so
Line 365: Only in /mnt/system/lib: libqmiservices.so
Line 366: Only in /mnt/system/lib: libqmi.so
Line 367: Only in /mnt/system/lib: libqsap_sdk.so
Line 368: Only in /mnt/system/lib: libqueue.so
Line 369: Only in /mnt/system/lib: libQWiFiSoftApCfg.so
Line 371: Only in /mnt/system/lib: libril-qc-1.so
Line 372: Only in /mnt/system/lib: libril-qc-qmi-1.so
Line 373: Only in /mnt/system/lib: libril-qcril-hook-oem.so
Line 375: Only in /mnt/system/lib: librpc.so
Line 380: Only in /mnt/system/lib: libsc-a2xx.so
Line 381: Only in /mnt/system/lib: libsecure_boot_keybox.so
Line 384: Only in /mnt/system/lib: libSHIMDivxDrm.so
Line 386: Only in /mnt/system/lib: libsnd.so
Line 395: Only in /mnt/system/lib: libsrsprocessing.so
Line 403: Only in /mnt/system/lib: libstagefrighthw.so
Line 428: Only in /mnt/system/lib: libSwypeCore.so
Line 432: Only in /mnt/system/lib: libtcpfinaggr.so
Line 434: Only in /mnt/system/lib: libtilerenderer.so
Line 435: Only in /mnt/system/lib: libtinyxml.so
Line 438: Only in /mnt/system/lib: libuim.so
Line 440: Only in /mnt/system/lib: libulp2.so
Line 441: Only in /mnt/system/lib: libulp.so
Line 444: Only in /mnt/system/lib: libv8.so
Line 446: Only in /mnt/system/lib: libvideochat_jni.so
Line 447: Only in /mnt/system/lib: libvideochat_stabilize.so
Line 453: Only in /mnt/system/lib: libvoem_if.so
Line 454: Only in /mnt/system/lib: libvoicerecorder.so
Line 458: Only in /mnt/system/lib: libwidevine.so
Line 459: Only in /mnt/system/lib: libwifidiag.so
Line 460: Only in /mnt/system/lib: libwifi_test.so
Line 462: Only in /mnt/system/lib: libwiperjni.so
Line 463: Only in /mnt/system/lib: libwiperjni_v01.so
Line 464: Only in /mnt/system/lib: libwms.so
Line 465: Only in /mnt/system/lib: libwmsts.so
Line 466: Only in /mnt/system/lib: libwnndict.so
Line 467: Only in /mnt/system/lib: libWnnEngDic.so
Line 468: Only in /mnt/system/lib: libWnnJpnDic.so
Line 470: Only in /mnt/system/lib: libwvm.so
Line 471: Only in /mnt/system/lib: libWVphoneAPI.so
Line 472: Only in /mnt/system/lib: libxml2.so
Line 473: Only in /mnt/system/lib: libxml.so
Line 475: Only in /mnt/system/lib: libzy_imgdenoise.so
Line 476: Only in /mnt/system/lib: modules
Line 477: Only in /mnt/system/lib: pp_proc_plugin.so
Line 478: Only in /mnt/system/lib: qnet-plugin.so
Line 486: Only in /mnt/system/lib: tcp-connections.so
diff_media.txt (64 hits)
Line 1: Only in /mnt/system/media/audio/alarms: Alarm_Beep_01.ogg
Line 2: Only in /mnt/system/media/audio/alarms: Alarm_Buzzer.ogg
Line 3: Only in /mnt/system/media/audio/alarms: Alarm_Classic.ogg
Line 4: Only in /mnt/system/media/audio/alarms: Alarm_Rooster_02.ogg
Line 5: Only in /mnt/system/media/audio/alarms: Aurora.ogg
Line 7: Only in /mnt/system/media/audio/alarms: Bond.ogg
Line 19: Only in /mnt/system/media/audio/alarms: TinMan.ogg
Line 20: Only in /mnt/system/media/audio/alarms: Twilight.ogg
Line 21: Only in /mnt/system/media/audio: animationsounds
Line 22: Only in /mnt/system/media/audio/notifications: 8bit.ogg
Line 23: Only in /mnt/system/media/audio/notifications: Abuzz.ogg
Line 31: Only in /mnt/system/media/audio/notifications: Arrow.ogg
Line 36: Only in /mnt/system/media/audio/notifications: Car_Lock.ogg
Line 39: Only in /mnt/system/media/audio/notifications: Champagne.ogg
Line 41: Only in /mnt/system/media/audio/notifications: Cuckoo.ogg
Line 45: Only in /mnt/system/media/audio/notifications: Dazzle.ogg
Line 47: Only in /mnt/system/media/audio/notifications: Digital.ogg
Line 50: Only in /mnt/system/media/audio/notifications: Easy.ogg
Line 59: Only in /mnt/system/media/audio/notifications: Kou_Xian.ogg
Line 64: Only in /mnt/system/media/audio/notifications: Microwave_Oven.ogg
Line 65: Only in /mnt/system/media/audio/notifications: Minds_Think_Alike.ogg
Line 68: Only in /mnt/system/media/audio/notifications: Old_Bicycle.ogg
Line 70: Only in /mnt/system/media/audio/notifications: Orpheus.ogg
Line 80: Only in /mnt/system/media/audio/notifications: Royal_Horn.ogg
Line 82: Only in /mnt/system/media/audio/notifications: Scrat.ogg
Line 85: Only in /mnt/system/media/audio/notifications: Sheep.ogg
Line 86: Only in /mnt/system/media/audio/notifications: Ship.ogg
Line 93: Only in /mnt/system/media/audio/notifications: Ticktack.ogg
Line 94: Only in /mnt/system/media/audio/notifications: Tinkly.ogg
Line 98: Only in /mnt/system/media/audio/notifications: Whistle.ogg
Line 105: Only in /mnt/system/media/audio/ringtones: Banana.ogg
Line 106: Only in /mnt/system/media/audio/ringtones: B_Box.ogg
Line 120: Only in /mnt/system/media/audio/ringtones: Cartoon.ogg
Line 122: Only in /mnt/system/media/audio/ringtones: Cat.ogg
Line 125: Only in /mnt/system/media/audio/ringtones: Classical_Blues.ogg
Line 133: Only in /mnt/system/media/audio/ringtones: Digital_Ringtone.ogg
Line 136: Only in /mnt/system/media/audio/ringtones: Doorbell.ogg
Line 139: Only in /mnt/system/media/audio/ringtones: Eastern.ogg
Line 141: Only in /mnt/system/media/audio/ringtones: Elevator_Bossa.ogg
Line 151: Only in /mnt/system/media/audio/ringtones: Good_Place.ogg
Line 152: Only in /mnt/system/media/audio/ringtones: Granola_Good.ogg
Line 153: Only in /mnt/system/media/audio/ringtones: Grassland_Dance.ogg
Line 154: Only in /mnt/system/media/audio/ringtones: Great_Journey.ogg
Line 156: Only in /mnt/system/media/audio/ringtones: Haight_Ashbury.ogg
Line 158: Only in /mnt/system/media/audio/ringtones: Harmonica.ogg
Line 160: Only in /mnt/system/media/audio/ringtones: Horse.ogg
Line 165: Only in /mnt/system/media/audio/ringtones: Latin_Jazz.ogg
Line 166: Only in /mnt/system/media/audio/ringtones: Little_Ditty.ogg
Line 174: Only in /mnt/system/media/audio/ringtones: Music_Box.ogg
Line 175: Only in /mnt/system/media/audio/ringtones: Mystic_Harp.ogg
Line 198: Only in /mnt/system/media/audio/ringtones: Sax.ogg
Line 201: Only in /mnt/system/media/audio/ringtones: September.ogg
Line 206: Only in /mnt/system/media/audio/ringtones: Siren.ogg
Line 208: Only in /mnt/system/media/audio/ringtones: Sneaky_Satellite.ogg
Line 210: Only in /mnt/system/media/audio/ringtones: Space.ogg
Line 211: Only in /mnt/system/media/audio/ringtones: Spring.ogg
Line 214: Only in /mnt/system/media/audio/ringtones: Summer.ogg
Line 215: Only in /mnt/system/media/audio/ringtones: Tap_Dance.ogg
Line 216: Only in /mnt/system/media/audio/ringtones: Technology.ogg
Line 225: Only in /mnt/system/media/audio/ringtones: Wake_Up.ogg
Line 226: Only in /mnt/system/media/audio/ringtones: Westlake.ogg
Line 227: Only in /mnt/system/media/audio/ringtones: Westminster.ogg
Line 243: Only in /mnt/system/media/audio/ui: VideoPause.ogg
Line 244: Only in /mnt/system/media/audio/ui: VideoRecordEnd.ogg
diff_usr.txt (7 hits)
Line 2: Only in /mnt/system/usr/keychars: 7x27a_kp.kcm
Line 3: Only in /mnt/system/usr/keylayout: 7k_handset.kl
Line 4: Only in /mnt/system/usr/keylayout: 7x27a_kp.kl
Line 5: Only in /mnt/system/usr/keylayout: atmel_mxt_ts.kl
Line 7: Only in /mnt/system/usr/keylayout: ft5x06_ts.kl
Line 9: Only in /mnt/system/usr/keylayout: surf_keypad.kl
Line 15: Only in /mnt/system/usr/srec: en-US
:D
Trying to unlock mine at the moment. Any onboard app I can download to do this?
Heck of a time getting correct drivers installed... keeps saying it is when it ain't. DC Unlocker error 231. Download mode. Bad driver. Arg!
