Remote control app for smartphone
Please recommend a good app.I want the app to be downloaded on my dad's smartphone which always is connected to 3g data and if any emergency arise or need to track can control the smartphone do certain operations like enabling gps which I can track through my custom app..Thanks
You might check out 'Android Device Manager' from the store. Just got my first S3 yesterday, and that was the first app I installed. It allows you to track your device and do other things like 'ring' it if it's close but lost, or remote lock/wipe it if all hope is lost. Not sure on what else can be enabled/disabled, but this might be a good start.
Thanks but that app won't determine location when gps is turned off so any other app which can turn on gps if it's off by giving commands through the smartphone app or any website bcoz the phone has 3g pack
