Remote Control my phone
My Android is non-rooted, touchscreen is not working and USB Debugging is turned off. I need to remotely turn on USB Debugging so that I may root the phone and reinstall the ROM. Please advise?
I find Airdroid (works w/ PC or Mac) the best for non-rooted phones.
It can replace the samsung keis program.
Has a nice visual desktop on the PC too.
remote controlling phone with PC or computer
The 'Realtime Android screen' is still experimental feature and need root permission... I can't root my phone since it would void warranty my phone.
Hi Guys ,
anyone knows an application that works on a non-rooted phones as a remote control like webkey , but with the condition that its server starts automatically after installing it and restarting the phone.
I need it urgently , as my phone is locked and i want to access it remotely to remove the password.
if you open the 'Play Store' now it mentions in the APPS = Webkey (ROOT REQUIRED)'
so please don't tell me you don't need root to use webkey.
I control my phone using java's screencast. controlling ones phone with the computer is still something experimental so methods out there may work but will be very laggy
Logmein rescue mobile + works flawless you have a full image of your phone and it works just like logmein for pc's only catch is its about 2k a year :D we have it for our company and have about 150 phones in the field so this works for us
Hi to everyone,
I'm also looking for a good remote control application for android devices but couldn't find one that works without problems.
@tballl :
You didn't had problems with LogmeIn application ?
I found a very annoying bug that doesn't let you install new applications through remote support(it blocks the interaction with the install button - for the user on the android device and also for the admin on the remote control - so there is no way to install new applications using the remote support)...
If you didn't got this bug can you explain what you did ?
The devices, what android version they run ? They are rooted or not ? From what OS did you started the remote support ? On what device models did you test this application ?
If anyone knows a working remote support application fro Android(and maybe IOS) can you please guide me into the correct direction ?
Thanks,
Ionut N.
