remote desktop
gil176740
Hi all,
I have purchased Zenithink 180 with android 2.1 installed.
I would like to connect my Epad directly to my Laptop with WIFI , and be able to control the desktop from the Epad.
The connection should be wireless with no routers and internet involved in the way.
The Idea is do run the laptop and display what is on it's screen on the Epad's screen.
How can I connect the two machines together with no internet or routers involved and what app should I install.
Thanks you all
Gil
No, The plan is to use the Epad as a remote extension of
the laptop on a yacht where there is no internet connection.
I can not run the navigation software on the Epad so I must find a way to show the screen of the laptop which has the maps on it.
In that way I can have an external screen on board that displays all the data.
