I would like to be able to tell my primary phone to activate call forwarding from the phone I use at work.
I have tried "forgot your phone" and "call forward". Both of them work the same way. They don't activate call forwarding but they do have your phone text call information (when and who) and received texts to the number you designate.
Once you set up a PIN on your phone you cab text a code to your phone including your PIN and the number you want the texts delivered to. Your phone then forwards a text with the details of what it receives.
The problem is that neither works. I've emailed the developers with no reply.
Any advice on these programs?
Any other apps you'd recommend?
