Removable Battery Phone List
philayl
Android Expert
Hi, I hope this is the correct place to post this, I am looking for a list of new smartphones with removable batteries, unfortunately the phone reviews do not always tell you this, and after many years of buying Samsung phones, because of the removable batteries, I now see that the S6 is using a non removable battery, so it is time to move on, but where to? Phil
An excellent source of information is at ... http://www.gsmarena.com/.
Simply do their search on the specific phone you are considering.
... Thom
I started to suggest their Phone Finder, which has a lot of options you can specify for a search (OS, release status, form factor, connectivity, microSD slot, etc) but they don't have a tickbox for "removable battery". :(
PhoneArena's similar Phone Finder does at least have a tickbox for "Battery: Not user replaceable". So maybe you could at least use that to eliminate some options :)
