Help Remove an unwanted icon
Begadoc
Samsung Galaxy 4 Note
Sorry for the vague title but I don't know what to call the icon in question and so can't search for answers in manual or here. I refer to the icon consisting of a blue circle with 4 squares in it. It gives quick access to various other things which are available elsewhere. While I can move this icon anywhere on the screen, I can't hide it or remove it and more often than not, wherever I leave it, it is in the way and I have to move it.
Is there any way of removing or hiding it?
Hello there!
Are you using the stock launcher or a different launcher?
Can you post a screenshot of the icon? Is the icon at the bottom or the sides of the screen?
Can you longpress on the icon and drag it to the trash can icon that appears when longpressing on it?
As I type this, I see that @Bg260 beat me to the punch with a reply :D He's a fast one!
OK - just to stop you both getting bored. How do I send you a screenshot (new toy - haven't figured that one out yet).
Incidentally, long press (I got bored pressng it) did nothing.
Capture a Screenshot - Samsung Galaxy Note® 4. To capture a screenshot, press the Power button (located on the upper-right edge) and the Home button (located at the bottom) at the same time. To view the screenshot you've taken, navigate: Apps > Gallery.
You can upload it here via the "upload a File" option under your reply box.
Are you posting from a computer, tapatalk, or your device? Uploading may vary depending on how you are posting here.
I'm posting using my PC. Screenshot attached. The offending icon is the blue circle with the 4 white squares.
Found this idea which may help:
Source
The floating blue circle/dot is the "Assistant Menu". To turn it off go into "Settings". Under the "Personal" section click on "Accessibility", then "Dexterity and interaction", then "Assistant menu". At the top of the "Assistant menu" window turn the switch to "off. The blue dot should then disappear.
