remove built-in aaps from Android
  • Thread starter Thread starter kashifnaqvi
  • Start date Start date
Hi
To do this you need to first root your device. Normally pre installed bloatware cannot be removed, although depending on your android version you may be able to disable them in
menu>applications manager.
Roger
Apps that are safe to remove are different by phone make/model.
As you did not give all necessary info I cannot direct you to a list/thread about removing your apps.
