Remove Home++?
mondev
Recently I installed BHMAN's 1.6 ROM without TW, and I'm having a problem where sometimes my clock widgets stop refreshing the time.
Now i've searched for this problem and usually the best solution to this is to delete any task managers installed, which I cannot because the task manager is embedded into Home++, so I'm thinking the only way to get rid of the task manager is to delete the whole Home++, correct?
How would I go about doing that?
I'm using ADW launcher at the moment.
If you long press on the clock widget in the task manager, you should be able to set it to ignore, which means its immune from being killed when you hit kill all.
If you still wish to remove home++, you will first need adb setup on your pc before I can help you further.
Yes I've added it to ignore with the built in task killer as well as advanced task manager, and it doesn't make a difference. The thing that's puzzling is that the task killer isn't showing up in the uninstaller when looking at apps, so it has to be embedded into Home++ correct?
I've also installed Pure Calendar and the thing disappears from my app list completely sometimes, really feel like the Home++ task killer is to blame.
I've also got better terminal on my phone, if that helps. I also have adb setup.
If you've got Home++, you're using the Warheads version of BH_Man's 1.6 No-TWiz.
Warheads was replaced by Take5 (which uses ADW Launcher)
Also, the OTA 1.6 No-TWiz ROMs also use ADW, if I'm not mistaken.
