Help Remove lag fix
aroid48
Hi i installed the ryanzas lag fix from the market a couple of days ago. yesterday i did a factory reset and reinstalled it to see if it was still applied so i can remove it. when i try to remove the extools thing it wont let me and when i try to undo lagfix it wont let me and when i try to reapply it it says there is one already applied. how do i completely get rid of it?
Nevermind guys i figured it out. thanks though.
when you click the undo option what did it say? When i clicked it the first time it had an error, broken pipe or something. I clicked it again and it went through but i thought it crashed because it was stuck on the same thing for a long time, so i clicked it again and it said there was already one applied. I just waited another 10 minutes and left it alone and voila its gone.
when i try to remove ext2 tools it says it appear you have a lag fix installed. removing ext2 tools could cause your device to no longer boot. (/system/bin/playlogos1 less than 5kb). i have to wait 40% battery charge before i can see what it says for undo lagfix.
okay so for lag fix it says you already appear to have on installed (/system/bin/playlogos1 less than 5 kb) and for undo lag fix it says i dont have one installed (free space on /data matches /data/data)
Care to give us a detailed explanation of what you did? Might help others out. No obligation, but I for one am curious.
i went into the bin folder and deleted the playlogos1 file and reinstalled it from the app and i had the option to undo the lag fix after that.
how did you remove the lag fix, how do I get to de Bin?
thanks.
Where do I find the bin
Uh...right in the middle of a Titanium Backup at the moment...when it's done I'll verify, but if I remember right it's /system/bin where you'll find playlogos1.
There are some folders that something like ES File Explorer or ASTRO File Manager can't read the contents of. Root Explorer (File Manager) - Android app on AppBrain sees all however. If you're rooted you should have this app anyway.
Just checked...yeah, that's where playlogos1 is located, /system/bin. On the root of the internal SD card if you've not been there before.
Had to do with this.
Hello, I need help here... I have the same problem with you, so i follow your solution by deleting the playlogos1 file. but when unable OCLF it said there is no playlogos1... What should I do next? How did you reinstall it? Thanx :)
What do you mean reinstalled it from the app? What app? Where?
thx
Edit: Never mind; found it. Scroll down LOL
ive done this about 4 times... oclf says installation successful reboot in 5 secs.... then im waiting for ages... and it doesnt reboot... just shuts down and vibrates every now and again... i try to turn it on and nothing wrks untill i restore factory settings... my bro has same phone (galaxy s 19000) with same firmware 2.2... wrked like a charm on his ... just having this prob with mine...
longest i've waited for a reboot was 4hrs.. other 3 times i've tryd 2 install oclf ive waited about 30mins for the reboot to happen when sadly i was disappointed when it never did...
CAN SOME1 PLS PLS HELP ME!!!
