Removed apps and users?
Smokey Joe
Does anyone know what "Removed apps and users" is, why it's using data, & how can I get rid of it?
Quote by:kernmal
When you uninstall an app that has used data, the amount of data that it used gets lumped into Removed Apps. The amount is cumulative.If you had two apps that each used 50MB of data you would normally see both apps listed. If you uninstalled both apps, they would disappear from the data usage listing and you would have a new listing for Removed Apps showing 100MB.
