Removed D1 Miui, Now Device has NO DEVICE ID? Help requested!
chooch551
Removed D1 Miui, in doing so, it removed my Device ID.. My Droid is currently flashed with Steel Droid Build No. 2.21 (Frg83d), the android Kernel, and updated 2.2.1, and was rooted at 2.2. Before flashing Miui, I chose not to update and was running Steel Droid at 2.2 with out any further updates. I was able to somehow flash Steel Droid back. I tried flashing baseband with no success. Any suggestions? I have no choice but to try Maderstcok340. Not sure on its success rate, but if this issue can be fixed without going that route, Life would be so much easier!
This is my first post, Hope I posted in the correct place!
Thanks,
Chooch
