removeind sd card
  • Start date Start date
A
Android Question
Guest
i want to take sd card out of machine to print pictures what procedure do i follow
We can assist you better if you let us know what device you're using. That said, powering it off entirely (not just pressing the power button, but usually long-pressing it) will make it safe to remove an SD card.
Hi
If your device allows you to take the sd card out with the device still on you should always do
menu
system settings
storage
unmount sd card
before taking it out. This tells the phone to stop using it so that taking it out doesnt create corrupt files/folders.
Roger
