Removing Items from Menu
Hey,
There are a few items on my menu that I don't want there. I know I can uninstall the ones I have downloaded and installed but how do I remove some of the others that are do not have the option to uninstall. I don't really want to uninstall them I just want them moved from the menu. Items such as the Desk Clock, Talk, Teeter and others.
Thanks
You would have to root to do this. There is another way though.. sorta...
Download LauncherPro... it will hide those icons for you. I got rid of a bunch of my junk Samsung ones I wasn't using that way.
Hey,
I don't have the same options as you so I have looked around.
I only have Settings for well settings. On there the options for the display and other settings.
Here are the options I have:
'Personalize' Which is to change the wallpapers and scenes.
'Sounds & Displays' which is for ring tones and others and Orientation, Animation, Brightness and screen timeout.
'Applications' which has option for allowing non-market apps to be installed. Manage and remove installed apps Running services to control and view currently running services.
Development to set options for apps development.
I don't have/see any others for the menu.
Hey,
It's been a while, but that sounds like the Sense menu. You would need to activate Launcher Pro as your home to use the Launcher Pro menus.
Hey,
You don't go into Settings for the phone itself...you go into Preferences for LauncherPro...accessed with Menu from the home page.
