Help removing jelly bean from gs3
I want to remove jelly bean from my gs3 and doe the OTA update because seems to be bugs in my manual updated one. I tried the factory reset but it did not remove the jelly bean 4.1. Thanks
Hello jessea2503 and welcome aboard. :)
I'm afraid you cannot remove the update once it's been updated. If I recall I believe you can downgrade your version if you root.
A factory reset only resets your data, settings and makes everything look like a new phone. You can use Odin to downgrade.
This is why im patiently waiting for the OTA one...I just have a bad feeling about the manual update.
