Help Removing Power menu options
  • Thread starter Thread starter pirpi
  • Start date Start date
P
pirpi
Guest
Hi all,
I have Chinese Tablets. I wanted to remove the default Power menu options such as (AIrplane Mode and Volume options).I have rooted them and copied framework-res.apk to edit the strings.xml and public.xml files. But after commenting lines related to airplane mode , recompiling the apk and coping back to the tablet, The device is not showing the power menu itself. When I long press power button,the device is getting rebooted. without showing the power menu options.
Instead of this rebooting directly I want options to be shown on the device when I long press power button.
Is there any way to achieve this?
Thanks
pirpi
