Make sure you have a rooted devise!!!
1. Download Terminal Emulator from the Android Market
2. Type the following commands
3. su (Press enter, will give SuperUser permissions)
4. mount -o remount,rw -t yaffs2 /dev/block/mtdblk3 /cust
5. ls /cust/cricket/us/app (brings up list of stock apps)
6. To remove a particular app, use the following command:
rm /cust/cricket/us/app/appname.apk
7. Make sure you type the app name exactly how it looks on the list *capital letters, lowercase, and numbers. I noticed if you use all lowercase it does not recognize the app*
8. Use the following command to make the apps directory again read-only:
mount -o remount,ro /dev/mtdblock3 /cust
I AM NOT RESPONSIBLE FOR YOUR MISTAKES
Message me if you need any help.
