Hi guys,
I have a Samsung Galaxy S2 with Android 2.3.4.
ICS should come soon (I hope) and I'll update it of course.
Anyway, there is something I would like to change, but I don't know if it's possible or if it will be possible.
I have 4 symbols that are always visible - at the bottom.
(When the cell phone is not locked of course.)
Phone - Contacts - Messaging - Applications
The first three ones make sense to me, I often use them.
However, the applications symbol is completely unnecessary to me.
I would like to replace it by the settings symbol.
There is an option to add/remove those symbols (I've seen it) but the application symbol cannot be removed.
This sucks if you ask me.
I mean even if you removed it and said, "Damn, I need it again", you could still add the symbol by the adding option.
I use the settings symbol several times a day, I could need that.
I know I could just add it to have 5, but this application symbol makes me kind of angry - lol.
Any ideas?
P.S: Can "symbol" also called "widget", or is this something else?
Any ideas?
