Help Renaming shortcuts
Matt43
How can I rename the shortcuts on my home page? I've read on this forum to use "Anycut" but it doesn't appear in my Market. Is there another app that'll do the same thing? Thanks
Check out BetterCut, but I do not believe their is a FREE version, only a $$ version... Also Desktop Visualizer, which is Free.......
Good Luck!
If you go to my thread called playlists, rosered kindly posted the barcode for this app. I deleted this one by mistake and couldn't find it on the market. You will need something like barcode scanner to do this if you don't already have it. Ric
Just cos I am a good guide and like to help!!!
