PeteCress
I'm using "Go Contacts" which, I'm guessing, uses the native Android contacts file.
After backing up via MobileGo, I find a "Contacts.contacts" file in the backup directory on my PC.
Rename Contacts.contacts to Contacts.contacts.xml, open it, and it becomes apparent that this is an XML file.
The Question:
Is there some way to render this file on my PC? I'm thinking an application that reads the .XML and throws up a suite of windows that mimic Go Contacts on the Android device.
Where I'm headed with this is a recovery scheme in case the Android device is lost.
I'm afraid to synch with gMail because I managed to hose my contacts a couple of times soon after migrating to the Android device. Can't swear that gMail was the target for those synchs, but it seems likely...
The Question:
