Help Replace battery? Where to buy?
I just took the battery out of mine and it's not that hard of a job..... IF you have mechanical ability. A heat gun is your friend in removing the Motorola label at the top(to get to 2 screws) and especially to get the battery out as it is really glued in and the cover on it is SOFT!!
WATCH power and volume rockers!! They like to fall out easily. The go back in but the volume rocker is kinda goofy how it fits in there.
Again it's a relatively easy job if you have basic mechanical skills.
The ribbon connectors are nice as can be. Well made.
Upvote 0
BEST TECH IN 2023
Smartphones
