Replacement Battery
paker
After 7 months, original battery wouldn't even hold a day of standby. I found 2400 mAH (compared to 1400 original) on ebay, but found contradicting reports. I am reporting that the yellow battery is at least as good as the original battery. I bought from ebay, a US seller. Both were 10 oz, same weight.
Just in case someone is wondering if the yellow battery is good....
there are many fake batteries in ebay so u gotta make sure that the one u r buying isn't fake, its kinda annoying. I've been thinking to buy a Ecell 2430mAh battery from amazon. Mobilefun sells 1800mAh batteries for SGA and it seems to be good, didnt saw much negative comments.
i got one off amazon excell or sumfin like that. and it 2/3's better that stock battery. i can leave my fone on with wifi, gps, bt, data all on and its lasts 1.5 days with use. Compared to 5 hours with the stock bat. i found it well worth the 12quid.
