Replacement battery
Mr. Boom
Anyone know what other HTC phone uses the same size battery as the Inc4g? What can be swapped?
I have been doing some reading and found at least two occasions where folks say they used the battery from the Inc2, and it fit and worked fine. I might try it.
Well, you may be right. I happen to have an Inc4G and a battery from an Inc2 handy, and it does look like they are the same. That said, if you are going to buy one, I would get the Inc4G battery, being that it's higher capacity.
Agreed, but i am looking at the stand alone battery chargers and if i get one, why not get it with a battery that will work. Just trying to explore options.
I tried the Hyperion brand white battery 2 pack and charger designed for the Inc 4G. I'm not happy with them as they discharge quicker than the stock battery. I gave it a week, and performance did not improve. I'm back to stock for now.
I might just pick up an OEM battery. But then again I am getting about four hours of screen time so I might not worry about it.
