Root Replacement Commando
bestaudioguy
Just replaced my commando with another since in a fit or rage I threw my original phone into a wall and cracked the glass.
I have the replacement and its already loaded with the M050 update.
Since my broken phone was rooted (M020) I am attempting to root the replacement, but for obvious reasons its not working.
I looked around but failed to see the steps needed for the M050 software.
Is there a link, or a set of step by step instructions to root this puppy?
What root program works on M050? I have Titanium Backup Pro on the phone along with SU.
Thanks!!!
Sorry about the other device . keep watch on them Cat like reflexes . but it maybe a better and simple way to root the device a lot of devs have made it better with just a one click method . and Google has removed somethings from the net I seen but the spelling makes a full key to what your seeking on the world wide web . but if you have the devs G+ account they may tell you its a new way and easier way .
Last I looked someone said moto chopper . DONT TRY IT UNLESS YOU GET THE ANSWERS. but that would be better than typing a book to root a device I feel you . and once you get it rooted you are afraid to use it . I know been there and said awwww h*ll with this thing .:eek::D
I Dont know about that cause many devs are finding rooting without a PC is very helpful no factory cable . just smiles
I also recently replaced a Commando and it came as a M050 as well. Motochopper running on a Windows 7 computer rooted it without issue.
I know it was asked and I got very tired of typing all these command . but hey it was one that worked I know it's a lot of root apps out and thanks to the dev that did the work
Not sure why Motochopper will not load. I think google chrome is stopping it before it even attempts to load.
I could try using IE or Firefox i guess.
I noticed this also with the uot theme kitchen wont load using this dam chrome . but the ie is doing it with no problem
