Hello kurk. Welcome to Android Forums. Congrats on the new phone. I'm not certain about your Ace. You likely need to insert the SD card into the Ace and then go into the menus and mount that SD card. Once mounted you will want to format it... it's always best to start with a fresh format... just to eliminate any possible problems. It should then be recognized by the phone and be ready to be written to.
For the very best help with you Ace and new SD card, you should check into the Ace area and ask for exact procedures. Here is a link to the Ace area: Samsung Galaxy Ace - Android Forums
Best of luck to you and thanks for joining this community.
