Req: PDF Editing on Samsung Galaxy Note
jf3000
I have a document that has a lot of fields to fill out and I wanted to know what is the easiest way to fill out these fields, the document is in PDF only. Cannot convert either. Must stay as PDF.
I will be using a Samsung Galaxy Note 10.1 4G
I will also be using the pen that comes with the tablet.
I have been using the adobe reader but the annoying part of the reader is when I click on e.g. First name in the document, rather than getting the keyboard I keep getting this yellow notepad thing open first to which I have to choose the keyboard to get rid of the notepad.
When it comes to boxes that require numbers there is no option on the keyboard to TAB to the next box to add another number. If anyone can give me some advice on what software to use, that would be awesome, thank you.
I need to be able to fill out a form, sign it with the pen, screenshot it then upload to dropbox.
Thank you
