Hi all,
I have a Samsung Galaxy S3 (International unlocked version) that I purchased from a 3rd party seller on Amazon. I'm experiencing a lot of network errors whenever I'm using the mobile network. Things seem to work fine when I'm on WiFi.
I would have apps fail to sign me in or fail to make facebook updates. Usually some kind of message appears saying "connection lost, tap to retry" or "failed to connect to 8tracks service". Some apps are so bad, that I have never actually got it to work (8tracks). Other apps work on and off (Facebook). More apps give similar errors (Yahoo finance). The reason I think it is the phone/OS is because it seems to be prevalent across many different apps. What is even weirder is if some apps are failing, I would immediately use another app and it would work just fine (Chrome); suggesting the network is up and running.
Of course, during all of this I clearly have a 3G/HSDPA signal (as seen in the status bar).
I understand network issues is a tricky problem to solve, so I'm open to any ideas - even if it requires me to install some debugging software. I'm not very familiar with the Android OS, but I'm fairly familiar with Linux so I can do some tcpdumps and systraces (if they exist on Android?).
