First off thanks to all devs and anyone else who helped
My question is how do I activate swap partition in kernel
My setup is cyan 11 with sdcard link2sd 8gb total
Partitioned something like 3.8 fat 3.7 ext4 and 3partition like 384 mb swap
Can't get it to work with ram extender pro
You have to build the kernel from source. And I don't know of any stock source for us.or you can modprobe your .KO file google is your best friend sir also try init support I believe its enabled under number two and gturns rom
