imnuts
Similar to Adrynalyne's post, I would greatly appreciate anyone that could do this. What I am looking for is a dump from a completely stock system, the only requirement is that you be rooted. So, if ANYONE has a completely stock Continuum and would be willing to do this, that would be great. Here are the steps to produce the files.
As root (#)
To backup the .lfs partition
To backup the kernel parition:
To backup the recovery partition:
To backup the system partition:
To backup the dbdata partition:
To backup the cache partition:
Once you have the files, zip/tar/7z them together and upload them to a sharing site (Dropbox, MediaFire, Megaupload, personal webhost, etc.) and post a link to them. If you don't want the link in the public, feel free to PM me a link to download the file. Once we have these, it will be much easier to do development work, especially with the voodoo kernel. Thank you to anyone that follows this and sends files. I'll update this post when I receive one or both system dumps (DJ20 and DL17).
As root (#)
Code:
dd if=/dev/block/stl6 of=/sdcard/param.lfs bs=4096
Code:
dd if=/dev/block/bml7 of=/sdcard/zImage bs=4096
Code:
dd if=/dev/block/bml8 of=/sdcard/recovery.bin bs=4096
Code:
dd if=/dev/block/stl9 of=/sdcard/factoryfs.rfs bs=4096
Code:
dd if=/dev/block/stl10 of=/sdcard/dbdata.rfs bs=4096
Code:
dd if=/dev/block/stl11 of=/sdcard/cache.rfs bs=4096
