Apps requestfeature() must be called before adding content error on onClick()
Joan Z
I have a fragment that have button and datepicker (among other stuffs). datepickerdialog will be displayed when user click the button. At first, I had a separate fragment for datepicker and I didnt have that error. but when I put the datepicker into the main fragment, I got this error when I click the button
Code:
android.util.AndroidRuntimeException: requestFeature() must be called before adding content
i don't have requestfeature() in my code. here is part of my MainActivity.java
Java:
public class MainActivity extends AppCompatActivity{
private Toolbar mToolbar;
@Override
    setContentView(R.layout.activity_main);
    //toolbar
    mToolbar = (Toolbar) findViewById(R.id.toolbar);
    setSupportActionBar(mToolbar);
    //database
    DbHelper databaseHelper = new DbHelper(this);
    databaseHelper.getWritableDatabase();
public void onClick(View view){
        DialogFragment dp = new MyFragment();
        dp.show(getSupportFragmentManager(), "date picker");
part of MyFragment.java
Java:
public class MyFragment extends DialogFragment implements DatePickerDialog.OnDateSetListener {
private View mRootView;
private Item currentItem = null;
private String Note;
private TextView dateText;
private TextView error;
private EditText item;
private EditText quantity;
private EditText note;
private Spinner sspinner;
private Spinner spinner;
private int spinnerCount=0;
private int spinnerInitializedCount=0;
private int remSpinnerCount=0;
private int remSpinnerInitializedCount=0;
public MyFragment() {
public static MyFragment newInstance(long id) {
    MyFragment myFragment = new MyFragment();
    if (id > 0) {
        Bundle bundle = new Bundle();
        bundle.putLong("id", id);
        myFragment.setArguments(bundle);
    return myFragment;
public void getCurrentItem() {
    Bundle args = getArguments();
    if (args != null && args.containsKey("id")) {
        long id = args.getLong("id", 0);
        if (id > 0) {
            currentItem = ItemManager.newInstance(getActivity()).getMyItem(id);
@Override
public void onCreate(Bundle savedInstanceState) {
    setHasOptionsMenu(true);
    getCurrentItem();
@Override
public View onCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState) {
    mRootView = inflater.inflate(R.layout.item_fragment, container, false);
    item=(EditText)mRootView.findViewById((R.id.item));
    quantity=(EditText)mRootView.findViewById(R.id.amount);
    error = (TextView)mRootView.findViewById(R.id.error);
    note = (EditText)mRootView.findViewById(R.id.notes);
    dateText = (TextView)mRootView.findViewById(R.id.date_selected);
    spinner = (Spinner) mRootView.findViewById(R.id.units);
    ArrayAdapter<CharSequence> adapter = ArrayAdapter.createFromResource(getActivity(), R.array.units, android.R.layout.simple_spinner_dropdown_item);
adapter.setDropDownViewResource(android.R.layout.simple_spinner_dropdown_item);
    spinner.setAdapter(adapter);
    sspinner = (Spinner) mRootView.findViewById(R.id.reminder_list);
    ArrayAdapter<CharSequence> aadapter = ArrayAdapter.createFromResource(getActivity(), R.array.countdown_reminder, android.R.layout.simple_spinner_dropdown_item);
    aadapter.setDropDownViewResource(android.R.layout.simple_spinner_dropdown_item);
    sspinner.setAdapter(aadapter);
    spinner.setOnItemSelectedListener(spinnerListener);
    sspinner.setOnItemSelectedListener(spinnerListener);
    spinnerCount=1;
    sspinnerCount=1;
    return mRootView;
public static final String[] months = {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"};
Calendar calendar = Calendar.getInstance();
private String selected_date;
@Override
public Dialog onCreateDialog(Bundle savedInstanceState){
    int year = calendar.get(Calendar.YEAR);
    int month = calendar.get(Calendar.MONTH);
    int date = calendar.get(Calendar.DATE);
    return new DatePickerDialog(getActivity(), this, year, month, date);
@Override
public void onDateSet(DatePicker view, int year, int month, int date) {
    calendar.set(year, month + 1, date);
    calendar.getTime();
    String mon = months[month];
    //get the selected date
    selected_date = ""+view.getDayOfMonth()+ "/" + ""+((view.getMonth())+1)+ "/" + "" +view.getYear();
    //Display the selected date after the date has been set
    dateText = (TextView)getActivity().findViewById(R.id.date_selected);
    dateText.setText(selected_date);
What's causing this error??? I'm assuming it's the datepicker since I didn't have that error til I added datepicker. Thank you in advance.
I've tried the solutions on SOF but I still get the same error or nullpointerexception. Clearly there's something I'm missing or not understand?
