Reset sharing defaults
_baseten
Hi I'm trying to find how to reset the 'always open with' setting for sharing functionality. Specifically in the Guardian app but it doesn't appear to be part of the preferences of the app itself. I have cleared all preferences and even reinstalled it. I am familiar with the 'clear defaults' method to remove these settings but am unsure as to what app I need to do this to for sharing functionality?
If you don't know which app is currently set as the default, you can take the shotgun approach:
Settings > Apps > (menu) > Reset app preferences, which will reset the Default App associations for all applications (along with data and notification restrictions, etc).
