alan666notb
I was playing around with different ringtones.
Until now, when I went to choose a new ringtone, I was offered the choice of using "Sound picker" or "Android system" to do so.
I have just set "Android system" as the default by ticking the box in the popup, but now I realize it doesn't give the same choices as "Sound picker".
But I can't clear the default setting, when choosing a new ringtone it goes straight to the "Android system" choices without giving me the choice to use "Sound picker".
Usually you can reset this by going into settings->Apps and clearing an App's defaults. But "Android system" isn't listed as an App.
There must be a setting somewhere else. Any idea where?
