colchiro
Extreme Android User
This works pretty good. My first TP I resized via the command line, but there's lots of calculations that needed to be done. I've used this method on 4 TP's now and like it better, although you need to have Preware installed first:
How to guide for changing your system, data, and cache partition sizes to whatever you want. - HP Touchpad - RootzWiki
I would think you'd want to make your system about 450 mb, which is about 50-60 mb bigger than the acme3 installer will resize it.
If you don't do this, you can delete the contents of the system/media folder, which will get you a few more megs.
