Help [Resolved] Issues waking up screen. using 360 with an LG G3
Gremlin256
Using the 360 with the LG G3 for the past two days. All of a sudden changed to a different watch face and now when I flick my wrist it does not show the time. I have to hit the button Any ideas?
try a different watch face. if it happens on that, could be an issue with the watch face app (watchmaker, etc)
reboot the phone, resync the apps, re-install the face.
what steps have you taken to troubleshoot? are you rooted ?
you say for the past 2 days you have been using this combination. explain? did you just pick up one or the other device or did you purchase them together? is one a replacement for another device?
both devices new? refurbs?
do you have a screen protector on the watch face?
are you wearing long sleeves, coat, etc when this issue happens?
just trying to get a time line on things.
What I meant for 2 days was, I had it working with one skin/face and I downloading others. I could get notifications and it would wake up.
Tried one face yesterday and it did not wake up after a couple of flicks, and I switched to the previous one and it worked. thought I would try a ferrari one today and that's when it stopped waking up on the flick of hand.
What I have done to try to fix it? Switched to the one that worked for me before. Than rebooted the watch. Reinstalled the face..
Both are new. No screen protector as of yet. Half shirt sleeves. You can root the watch? so it is not :)
I will resync the apps and try it again.. Thank you :)
the phone can be rooted, hence why i asked.
i use this watch with a nex 6 and after trying 4 or 5 faces, they all worked fine and did not impede the operation of the watch (flicking the wrist, notifications, etc.)
perhaps some faces work and some dont. that is what i get from your response.
Well resynching apps did not work.. So I factory reset the watch everything is back to normal. even i tried the face that caused the problem.. So go figure...
Thank you for your help :)
