I keep being annoyed that when I get in the car, the S2 (Android v4.1) does not connect.
The reason is always the same, which is that I have had it connected to the PC via USB, that automatically switches off BlueTooth and I forget to switch it on again.
So, is there any way either:
Any ideas?
Thank you!
- To prevent USB connection switching off BT, or
- Have BT start up again when USB disconnected?
Any ideas?
Thank you!
