Dominosdad
Today my device (again) crashed on being switched on, and said it had to go back to factory reset, it also said that afterwards it would give me the option to restore from the back up.
It did not do so. There was nothing of the sort. The device was back to manufacturer condition with nothing of mine at all: Not even the stuff that had been installed to external card.
Backup and restore claims that that it will restore automatically. But there isn't anyway to tell it to do it if it doesn't do so automatically. So is there a way to force the restore?
Quote from Google's Android web pages.
"After resetting your phone, you'll need to re-enter the same information requested when you first set up your phone. If you've been backing up your data to a Google account, an option during the setup process allows you to restore it."
But this just didn't happen.
And previously I had a crash on boot and it was the same then.
