Help restore factory setting and hard reset not working in huawei phone
TAYYAB
Dear Experts ,
i am having some problem with my huwei phone.
i try to erase every thing it did not work for me ,
i did hard reset ( vol up + volume down + power button ) but it is also not working for me.
any suggestion tips in this matter.
regards
What's not working? Are you able to access recovery and the factory reset option didn't work or did you not get there at all?
Does the phone still boot normally? If so, there should be an option in the phones settings to factory reset.
If all else fails and you don't have boot, you can think about flashing the stock firmware if its publicly available. That's the most invasive option so let's see what responses you have to the above questions before going down that road.
phone is booting normally but factory reset and hard reset not working.
i also try to upgrade firmware with usb method but that is also not working.
You're phone appears to have died TAYYAB. If factory reset using buttons and/or software don't work and if you flashed a new ROM using the USB method and it still doesn't work then you have to think of something else to use your deceased device for. If it still lets you get on the internet it would make a dandy YouTube viewer.
