Restore factory setting
If i restore factory setting will it be dangerous to my phone??
please help
and oh, i also want to ask about how do you integrate all your social networking feeds on your contacts. thanks
please help
It's perfectly safe to do a factory reset.
Settings/accounts and sync to intergrate your social networking feeds.
thank you so much gammer.. haha.. hmm one more thing i don't know how to bACK UP and restore.. can you teach me how? thanks in advance :)
what all will get erased after restoring factory settings???
Everything that is not on the sd card, it will become just like when you took it out of the box for the first time.
You can format the card also along with it, there is an option for that too.
Hello everyone, I have a huge problem, I accidentally wiped everything thinking it would do no harm but now my Samsung Galaxy ace does not load, it turns on and shows the samsung logo and then just restarts again!
What can I do? I had android 2.3.6 but when I plug my phone into computer to flash it it syas error installing driver.. help!
Take out the battery, put it back in after a few seconds [its just to stop the bootloop and have the phone turned off]
Now restart the phone in recovery mode by pressing and holding Home + Power button, keep it pressed until you see the yellow recovery menu.
Click on wipe cache partition and factory/data reset and then reboot system.
Use the volume keys to navigate and home key to select.
Hope this solves the problem, otherwise you will have to flash the entire firmware again.
do we require pin or something for restoring factory settings or just need to following the instruction will do
No pin, just follow the instructions. Just click the option, then it'll ask a confirmation, press yes. It might give an option to include sd card as well, but you probably want to exclude it from getting erased, so that option is NO.
